2007 Cadillac STS ASHTRY
2007 CADILLAC STS
VCARBOND
Interior problem
2007 Cadillac STS Two Wheel Drive Automatic
How do I remove the ashtray? Some coins fell back behind it and I need to get them out.
Mar 2, 2010 at 9:51 AM
FACTORYJACK
  • 4,159 POSTS
Ashtray Replacement
Removal Procedure
Remove the center instrument panel trim. Refer to Instrument Panel Center Trim Panel Replacement .
Remove the 4 screws (1) securing the ashtray.
Disconnect the electrical connectors.
Installation Procedure
Connect the electrical connectors.
Notice: Refer to Fastener Notice in the Preface section.
Install the 4 screws (1) securing the ashtray.
Tighten
Tighten the screws (1) to 9 N·m (80 lb in).
Install the center instrument panel trim. Refer to Instrument Panel Center Trim Panel Replacement .
Removal Procedure
Important: Use plastic stick trim tool for removal.
Carefully pull outward from the bottom of the center trim along the outboard edges and carefully work upward to prevent breaking the center trim.
Remove the trim from the instrument panel.
Locate the center trim onto the instrument panel.
Starting at the bottom and working your way to the top, push on the center trim in order to secure the retaining clips.
Mar 2, 2010 at 10:28 PM
