DTC P0440
System Description
The control module tests the evaporative emission (EVAP) system for a large leak. The control module monitors the fuel tank pressure (FTP) sensor signal to determine the EVAP system vacuum level. When the conditions for running are met, the control module commands the EVAP canister purge valve OPEN and the EVAP vent valve CLOSED . This allows engine vacuum to enter the EVAP system. At a calibrated time, or vacuum level, the control module commands the EVAP canister purge valve closed, sealing the system, and monitors the FTP sensor input in order to determine the EVAP system vacuum level. If the system is unable to achieve the calibrated vacuum level, or the vacuum level decreases too rapidly, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister purge and vent valves.
Control Module Command
EVAP Canister Purge Valve
EVAP Canister Vent Valve
ON
Open
Closed
OFF
Closed
Open
Conditions for Running the DTC
• DTC P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0121, P0122, P0123, P0125, P0443, P0449, P0452, P0453, P1106, P1107, P1112, P1114, P1115, P1121, P1122 are not set.
• The ignition voltage is between 10-18 volts.
• The barometric pressure (BARO) is more than 75 kPa.
• The fuel level is between 15-85 percent.
• The start-up engine coolant temperature (ECT) is less than 30°C ( 86°F).
• The intake air temperature (IAT) is between 4-30°C (39-86°F).
• The start-up ECT and IAT are within 9°C (16°F) of each other.
• The vehicle speed sensor (VSS) is less than 121 km/h (75 mph).
Conditions For Setting the DTC
The EVAP system is not able to achieve or maintain vacuum during the diagnostic test.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
• To help locate intermittent leaks, use the J 41413-200 Evaporative Emissions System Tester (EEST) to introduce smoke into the EVAP system. Move all EVAP components while observing smoke with the J 41413-SPT High Intensity White Light.
• A temporary blockage in the EVAP purge solenoid, purge pipe or EVAP canister could cause an intermittent condition. Inspect and repair any restriction in the EVAP system.
• To improve the visibility of the smoke exiting the EVAP system, observe the suspected leak area from different angles with the J 41413-SPT .
• Reviewing the Failure Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
• For intermittent conditions refer to Intermittent Conditions.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Introducing smoke in 15 second intervals may allow smaller leak areas to be more noticeable. When the system is less pressurized, the smoke will sometimes escape in a more condensed manner.
This step verifies proper operation of the fuel tank pressure (FTP) sensor.
A normal operating FTP sensor should increase above 5 inches of H2O and stop between 6 inches of H2O and 7 inches of H2O.
Step
Action
Values
Yes
No
Schematic Reference: Evaporative Emissions Hose Routing Diagram
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Inspect the Evaporative Emission (EVAP) System for the following conditions:
• A loose, missing, or damaged service port schrader valve
• A loose, incorrect, missing, or damaged fuel fill cap
• A damaged EVAP purge solenoid
Raise the vehicle on a hoist. Refer to Lifting and Jacking the Vehicle in General Information.
Inspect the EVAP system for the following conditions:
• Any disconnected, improperly routed, kinked, or damaged EVAP pipes and hoses
• A damaged EVAP vent solenoid or EVAP canister
Did you find and correct the condition?
Go to Step 17
Go to Step 3
3
Important: Larger volume fuel tanks and/or those with lower fuel levels may require several minutes for the floating indicator to stabilize.
Turn OFF the ignition.
Connect the J 41413-200 Evaporative Emissions System Tester (EEST) power supply clips to a known good 12-volt source.
Turn the nitrogen/smoke valve to nitrogen.
Connect the nitrogen/smoke hose to the 0.5 mm (0.20 in) test orifice on the bottom-front of the J 41413-200 .
Use the remote switch to activate the J 41413-200 .
Align the red flag on the flow meter with the floating indicator. Use the remote switch to de-activate the J 41413-200 .
Install the J 41415-40 Fuel Tank Cap Adapter to the fuel fill pipe.
Install the fuel fill cap to the J 41415-40 .
Remove the nitrogen/smoke hose from the test orifice and install the hose onto the J 41415-40 .
Turn ON the ignition, with the engine OFF.
Command the EVAP canister vent solenoid valve closed with a scan tool.
Use the remote switch to introduce nitrogen and fill the EVAP system until the floating indicator stabilizes.
Compare the flow meter's stable floating indicator position to the red flag.
Is the floating indicator below the red flag?
Go to Step 6
Go to Step 4
4
Important: Ensure that the vehicle underbody temperature is similar to the ambient temperature and allow the surrounding air to stabilize before starting the diagnostic procedure. System flow will be less with higher temperatures.
Install the J 41415-40 to the fuel fill pipe.
Connect the fuel fill cap to the J 41415-40 .
Connect the J 41413-200 nitrogen/smoke supply hose to the J 41415-40 .
Turn ON the ignition with the engine OFF.
Command the EVAP vent solenoid closed with a scan tool.
Turn the nitrogen/smoke valve on the J 41413-200 control panel to SMOKE.
Use the remote switch to introduce smoke into the EVAP system.
Use the J 41413-VLV EVAP Service Port Vent Fitting to open the EVAP service port.
Remove the J 41413-VLV once smoke is observed.
Continue to introduce smoke into the EVAP system for an additional 60 seconds.
Inspect the entire EVAP system for exiting smoke with the J 41413-SPT High Intensity White Light.
Continue to introduce smoke at 15 second intervals until the leak source has been located.
Did you locate and repair a leak source?
Go to Step 21
Go to Step 5
5
Disconnect the J 41415-40 from the fuel fill pipe.
Install the fuel fill cap to the fuel fill pipe.
Connect the J 41413-200 nitrogen/smoke supply hose to the EVAP service port.
Inspect the entire EVAP system for exiting smoke with the J 41413-SPT .
Go to Step 21
Go to Step 6
6
Use the remote switch to stop introducing smoke.
Connect the vehicle fuel fill cap to the J 41415-40 .
Command the EVAP vent solenoid open with a scan tool.
Compare the Fuel Tank Pressure Sensor parameter with a scan tool, to the J 41413-200 pressure/vacuum gauge.
Is the scan tool Fuel Tank Pressure Sensor parameter within the specified value of the J 41413-200 pressure/vacuum gauge.
1 in H2O
Go to Step 7
Go to Step 18
7
Seal the EVAP system using the EVAP Purge/Seal function with a scan tool.
Turn the nitrogen/smoke valve on the J 41413-200 control panel to NITROGEN.
Use the J 41413-200 to pressurize the EVAP system to the first specified value.
Is the Fuel Tank Pressure Sensor parameter more than the second specified value?
10 in H2O
5 in H2O
Go to Step 8
Go to Step 14
8
Use the remote switch to stop introducing nitrogen into the EVAP system.
Increase the EVAP purge solenoid to 100 percent.
Is the Fuel Tank Pressure Sensor parameter Less than the specified value?
1 in H2O
Go to Step 9
Go to Step 11
9
Connect the nitrogen/smoke hose to the EVAP service port.
Remove the J 41415-40 .
Start the engine.
Allow the engine to idle.
Use the purge/seal function to seal the system with a scan tool.
Command the EVAP purge solenoid to 30 percent.
Observe the vacuum/pressure gauge on the J 41413-200 and the FTP parameter on the scan tool.
Allow the vacuum to increase on the gauge of the J 41413-200 , until it reaches approximately 16 inch H2O.
Is the FTP parameter on the scan tool within the specified value of the vacuum/pressure gauge on the J 41413-200 , until the vacuum reached the abort limit on a scan tool.
1 in H2O
Go to Step 10
Go to Step 14
10
Did the FTP parameter on a scan tool display more than the specified value?
3.2 V
Go to Diagnostic Aids
Go to Step 14
11
Disconnect the EVAP purge pipe from the EVAP purge solenoid.
1 in H2O
Go to Step 19
Go to Step 12
12
Disconnect the EVAP purge pipe at the EVAP canister.
1 in H2O
Go to Step 17
Go to Step 13
13
Disconnect the EVAP vapor pipe at the EVAP canister.
1 in H2O
Go to Step 20
Go to Step 16
14
Test for an intermittent and for a poor connection at the fuel tank pressure (FTP) sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 15
15
Test the low reference circuit of the FTP sensor for an open or for high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 18
16
Repair the pinched or obstructed EVAP vapor pipe.
Did you complete the repair?
Go to Step 21
17
Repair the restriction in the EVAP purge pipe. Refer to Evaporative Emission Line Replacement - Engine to Chassis.
Go to Step 21
18
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement.
Did you complete the replacement?
Go to Step 21
19
Replace the EVAP purge solenoid. Refer to Evaporative Emission Canister Purge Solenoid Valve Replacement.
Go to Step 21
20
Replace the EVAP canister. Refer to Evaporative Emission Canister Replacement.
Go to Step 21
21
Perform the Service Bay Test. Refer to Service Bay Test.
Does the scan tool indicate that the Service Bay Test passed?
Go to Step 22
Go to Step 2
22
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Mar 2, 2010 at 10:22 PM
