If you smell it in the car, I need you to check around the fuel injectors. There are 0-rings that can leak and they are hard to detect. Also, has the check engine light come on? I ask because there could be a leak in the EVAP system which can cause a smell.
Finally, if you smell it in the garage, check the down pipe (filler tube) where you place gas from under the car. I have seen them rust and get pin holes in them. The fumes make it into the car at times.
Let me know what you find.
Oct 7, 2009 at 8:52 PM
