2001 Cadillac STS HUB WHEEL ASSEMBLY
2001 CADILLAC STS
140,000 MILES • V8 • 2WD • AUTOMATIC
DONNYA
HOW TO CHANGE FRONT PASSENGER HUB WHEEL ASSEMBLY AND IS IT DIFFUCULT?
Nov 20, 2009 at 9:42 AM
FACTORYJACK
  • 4,159 POSTS
It requires some tools, not very difficult. First need to remove wheel, brake caliper and rotor. Remove the axle nut(I think 32mm), disconnect the sensor connector, push the axle stub in to provide more room to access hub bolts. These three bolts are pretty tight, and can easily have the heads rounded off. Then push the axle in to provide room for the sensor connector to pass through, and reverse to reinstall.
Nov 21, 2009 at 10:03 AM
