1995 Cadillac SRX - STS THEFT SYSTEM
1995 CADILLAC STS
195,000 MILES • V8 • FWD • AUTOMATIC
MZ.S1MPK1NZ
  • 4 POSTS
TRY TO START, TAKES SEVERAL TRIES B4 STARTING. GET MESSAGE SAYING "THEFT SYSTEM MODE VEHICLE MAY NOT RESTART" HAVE ANY SUGGESTIONS? ALSO HAVE COOLANT LEAKING, HAVE CHECKED & LOOKS LIKE TOP PUT NUMEROUS TOPS ON STILL NO HELP,BUT LAST 2 WEEKS HAVE STOPPED BUT WAS DOING IT ALL THE TIME OVER MONTHS.
Apr 14, 2008 at 8:55 AM
BUZZSAW
  • 1,198 POSTS
[quote:7cceaf97c3="MZ.S1MPK1NZ"]Engine Mechanical problem
1995 Cadillac SRX - STS V8 Front Wheel Drive Automatic 195000 miles
TRY TO START, TAKES SEVERAL TRIES B4 STARTING. GET MESSAGE SAYING "THEFT SYSTEM MODE VEHICLE MAY NOT RESTART" HAVE ANY SUGGESTIONS? ALSO HAVE COOLANT LEAKING, HAVE CHECKED & LOOKS LIKE TOP PUT NUMEROUS TOPS ON STILL NO HELP,BUT LAST 2 WEEKS HAVE STOPPED BUT WAS DOING IT ALL THE TIME OVER MONTHS.[/quote:7cceaf97c3]
your ign switch is bad for the theft sys, your not clear on the coolant leaks
Apr 15, 2008 at 1:43 PM
MZ.S1MPK1NZ
  • 4 POSTS
[quote:c6fecf9b79="Buzzsaw"][quote:c6fecf9b79="MZ.S1MPK1NZ"]Engine Mechanical problem
TRY TO START, TAKES SEVERAL TRIES B4 STARTING. GET MESSAGE SAYING "THEFT SYSTEM MODE VEHICLE MAY NOT RESTART" HAVE ANY SUGGESTIONS? ALSO HAVE COOLANT LEAKING, HAVE CHECKED & LOOKS LIKE TOP PUT NUMEROUS TOPS ON STILL NO HELP,BUT LAST 2 WEEKS HAVE STOPPED BUT WAS DOING IT ALL THE TIME OVER MONTHS.[/quote:c6fecf9b79]
your ign switch is bad for the theft sys, your not clear on the coolant leaks[/quote:c6fecf9b79]
THANK YOU VERY MUCH FOR THAT INPUT BUZZSAW. I WILL DEFINITELY HAVE MY IGN CHECKED OUT. ALSO, AS FOR MY COOLANT, IT JUST KEEPS LEAKING AND IT SEEMS TO BE LEAKING FROM THE TOP/CAP ON THE RADIATOR AND HAS BEEN FOR ABOUT 6-8 MONTHS, BUT LIKE I SAID JUST DAYS AGO, IT STOPPED. HELP!!
Apr 15, 2008 at 3:00 PM
BUZZSAW
  • 1,198 POSTS
[quote:f2c74d9236="MZ.S1MPK1NZ"][quote:f2c74d9236="Buzzsaw"][quote:f2c74d9236="MZ.S1MPK1NZ"]Engine Mechanical problem
TRY TO START, TAKES SEVERAL TRIES B4 STARTING. GET MESSAGE SAYING "THEFT SYSTEM MODE VEHICLE MAY NOT RESTART" HAVE ANY SUGGESTIONS? ALSO HAVE COOLANT LEAKING, HAVE CHECKED & LOOKS LIKE TOP PUT NUMEROUS TOPS ON STILL NO HELP,BUT LAST 2 WEEKS HAVE STOPPED BUT WAS DOING IT ALL THE TIME OVER MONTHS.[/quote:f2c74d9236]
your ign switch is bad for the theft sys, your not clear on the coolant leaks[/quote:f2c74d9236]
THANK YOU VERY MUCH FOR THAT INPUT BUZZSAW. I WILL DEFINITELY HAVE MY IGN CHECKED OUT. ALSO, AS FOR MY COOLANT, IT JUST KEEPS LEAKING AND IT SEEMS TO BE LEAKING FROM THE TOP/CAP ON THE RADIATOR AND HAS BEEN FOR ABOUT 6-8 MONTHS, BUT LIKE I SAID JUST DAYS AGO, IT STOPPED. HELP!![/quote:f2c74d9236]
is it overheating? you need to have it pressure tested, ck the water pump belt and tensioner its on the front head drivers side you have to take off a bracket its 1 10mm bolt, another ck; turn the AC on go to the front of the motor and a fan should be running up front
Apr 16, 2008 at 12:45 AM
MZ.S1MPK1NZ
  • 4 POSTS
[quote:78cf258824="Buzzsaw"][quote:78cf258824="MZ.S1MPK1NZ"][quote:78cf258824="Buzzsaw"][quote:78cf258824="MZ.S1MPK1NZ"]Engine Mechanical problem
TRY TO START, TAKES SEVERAL TRIES B4 STARTING. GET MESSAGE SAYING "THEFT SYSTEM MODE VEHICLE MAY NOT RESTART" HAVE ANY SUGGESTIONS? ALSO HAVE COOLANT LEAKING, HAVE CHECKED & LOOKS LIKE TOP PUT NUMEROUS TOPS ON STILL NO HELP,BUT LAST 2 WEEKS HAVE STOPPED BUT WAS DOING IT ALL THE TIME OVER MONTHS.[/quote:78cf258824]
BUZZSAW,
I HAVEN'T NOTICED IT OVERHEATING JUST LOOSING COOLANT AND RIGHT MUCH OF IT INFACT. I WILL PAY CLOSER ATTENTION TO THE TEMP HAND.
your ign switch is bad for the theft sys, your not clear on the coolant leaks[/quote:78cf258824]
THANK YOU VERY MUCH FOR THAT INPUT BUZZSAW. I WILL DEFINITELY HAVE MY IGN CHECKED OUT. ALSO, AS FOR MY COOLANT, IT JUST KEEPS LEAKING AND IT SEEMS TO BE LEAKING FROM THE TOP/CAP ON THE RADIATOR AND HAS BEEN FOR ABOUT 6-8 MONTHS, BUT LIKE I SAID JUST DAYS AGO, IT STOPPED. HELP!![/quote:78cf258824]
is it overheating? you need to have it pressure tested, ck the water pump belt and tensioner its on the front head drivers side you have to take off a bracket its 1 10mm bolt, another ck; turn the AC on go to the front of the motor and a fan should be running up front[/quote:78cf258824]
Apr 16, 2008 at 11:55 AM
