2004 Cadillac SRX Trasfer Case
2004 CADILLAC SRX
94,000 MILES • V8 • AWD • AUTOMATIC
PHELANLAND
Transfer Case replacement
Jul 7, 2009 at 7:34 PM
FACTORYJACK
  • 4,159 POSTS
Transfer Case Assembly Replacement
Removal Procedure
Drain the transfer case fluid, if necessary. Refer to Transfer Case Fluid Replacement .
Remove the exhaust system. Refer to Exhaust System Replacement .
Remove the rear propeller shaft. Refer to Rear Propeller Shaft Replacement .
Support the transmission with a suitable screw jack and a block of wood.
Remove the transmission mount-to-body bolts.
Using the jack, lower the transmission enough to access the transmission mount-to-transfer case mounting bolts.
Remove the transmission mount-to-transmission case mounting bolts.
Remove the transmission mount assembly from the vehicle.
Remove the front propeller shaft. Refer to Front Propeller Shaft Replacement .
Jul 7, 2009 at 10:39 PM
PHELANLAND
What is the estimated repair cost?
Jul 8, 2009 at 12:28 AM
FACTORYJACK
  • 4,159 POSTS
With the info I have, the case is approx $1600 with approx 4 hrs labor at shop rate. That will put you in the $2000 range.
Jul 8, 2009 at 12:42 AM
