compression test shows low compression#6 cylinder. with new heads would there be blow back to lower block(pistons,rings ,seals} are there any products that may restore compression, since vehicle runs smooth with no loss of power. had check engine light on that indicated misfire, bank 2 downstream oxygen sensor and mass air flow sensor. mechanic said that with replacement of those parts with new air filter the problem would not be fixed.
Jun 21, 2014 at 6:30 AM
