2000 Cadillac SLS Power steering fluid leak
2000 CADILLAC SLS
80,000 MILES • V8 • 2WD • AUTOMATIC
MCCLIN11
Is there an easy fix for a power steering fluid leak?
Jul 21, 2010 at 8:42 AM
FACTORYJACK
  • 4,159 POSTS
The easiest fix would be to tighten a loose fitting. The first step is to determine where it leaks. There is a probability it is the pump, pressure hose, or gear. The pressure hose is common, but without seeing, it would be just a guess.
Jul 24, 2010 at 12:28 AM
