I just got a 2000 SLS, everything is great except I think the car is too smart for its self!
I got a diagnostic done and it showed the oil pressure sensor is failing and the crank position senor is failing.
Now all said and done more things are popping up, the change brake pads - had the wire replaced but still comes up, check stability system and when that came on the traction control / ABS light turned on- does that mean its engaged or needs to be checked??, the speed limited to 90 is flashing - going 30mph or 60 mph, and finally the engine has this ticking sound when you first start it up or rev the engine while in park.
Can someone tell me if I have major issues or are these pretty small fixes ($$)
Also would anyone recommend always taking it to a caddi dealer or any shop will do.
Thanks
Thanks
Feb 10, 2009 at 1:07 PM
