2000 Cadillac SLS
2000 CADILLAC SLS
GOOSTA
  • 6 POSTS
Computer problem
2000 Cadillac SLS V8 Two Wheel Drive Automatic
why does my dtc flash messages that are incorrrect
Mar 22, 2010 at 4:55 PM
FACTORYJACK
  • 4,159 POSTS
Need more specifics. What are the messages, and how are they determined to be incorrect?
Mar 22, 2010 at 10:56 PM
GOOSTA
  • 6 POSTS
Engine hot and it's not. Traction stabilizing. The seats constantly adjust and re-adjust. Check coolant, but it's okay.
Mar 22, 2010 at 11:26 PM
FACTORYJACK
  • 4,159 POSTS
For one, a faulty coolant level sensor, which is part of the reservoir, could be at fault for the check coolant message. Is the engine getting hot?, how has it been determined it is not, by the gauge? When it shows traction engaged, is there any noise like ABS activation, or a feeling of torque reduction at the time. When do the seats adjust and readjust, during remote pressings or ignition key insertion? I don't think that these messages can be presumed false, They are relatively unrelated, and not too uncommon. Other than the seats adjusting and readjusting.
Mar 22, 2010 at 11:43 PM
GOOSTA
  • 6 POSTS
So i should have sensors check, instead of assumings dtc is faulty. And how do I have them checked?
Mar 22, 2010 at 11:51 PM
FACTORYJACK
  • 4,159 POSTS
You can disconnect the coolant level sensor, it is on the bottom of the reservoir. If you no longer have a message, that is what is turning IT on. Is this coolant level message intermittent in nature, or always on? The traction message, if it is traction engaged(or active), may be inadvertent. The best thing to do would be to enter diagnostics by pressing info up, and on/off. After the segment check, it will display ALL?, press on/off again, it will display ALL CODES?, and press on/off again. Have a writing utensil, and a piece of paper and record all codes. If there are no codes relevant to your symptoms, I may not be of much help over the net. It would require more of a hands on approach to diagnosis.
Mar 25, 2010 at 10:50 PM
GOOSTA
  • 6 POSTS
They r all intrermittent. Will check info center.
Mar 25, 2010 at 11:21 PM
