You can disconnect the coolant level sensor, it is on the bottom of the reservoir. If you no longer have a message, that is what is turning IT on. Is this coolant level message intermittent in nature, or always on? The traction message, if it is traction engaged(or active), may be inadvertent. The best thing to do would be to enter diagnostics by pressing info up, and on/off. After the segment check, it will display ALL?, press on/off again, it will display ALL CODES?, and press on/off again. Have a writing utensil, and a piece of paper and record all codes. If there are no codes relevant to your symptoms, I may not be of much help over the net. It would require more of a hands on approach to diagnosis.
Mar 25, 2010 at 10:50 PM
