Sure. Water pump is on the right side of the engine at the top. I believe it's on a separate belt.
REMOVAL:
Drain the coolant.
Remove or disconnect the following:
Negative battery cable
Upper fill panel, if equipped
AIR injection control valve, if equipped
Air cleaner
Oil level indicator tube nut, if necessary
Water pump belt cover
Water pump drive belt
Lower radiator hose
Thermostat bypass hose from the coolant inlet housing
Water pump cover
Remove the water pump by rotating it clockwise using special Tool J 38816-1A (water pump remover/installer).
INSTALLATION:
Install the water pump with a new O-ring, by turning it counterclockwise using the special tool, until it stops. Torque the water pump to 73 ft. lbs. (100 Nm).
Install or connect the following:
Water pump cover. Torque the bolts to 89 inch lbs. (10 Nm).
Lower radiator hose
Thermostat bypass hose to the coolant inlet housing
Air cleaner
Refill and bleed the cooling system.
Run the engine and check for leaks.
Hope this helped. Thanks for using 2carpros.com!
Nov 14, 2008 at 8:14 PM
