I have a 1999 Cadillac SLS. I am getting a message on the display service AC system. I am able to run a diagnostic on the system. In order for me to be able to run this test, I had to look up a 2000 model. The 1999 model would not work. I am able to reset the code, and the compressor will come on for a brief second. I would like to check the system but am unable to find the low presser test point. Can you help me out on this? Here is the list of codes. I am hoping you could tell me what they mean? My email address is [email protected]
Thank you,
Albert
ABS= no code
AMP= no code
DDM= no code
DIM= B1324 History
IPC= no code
IRC= no code
PCM= P0533 current
RFA= no code
RIM= no code
SDM=no code
VTD= B2947 History
MSM= B1860 History
TTM= no code
RSS= no code
Thank you,
Albert
ABS= no code
AMP= no code
DDM= no code
DIM= B1324 History
IPC= no code
IRC= no code
PCM= P0533 current
RFA= no code
RIM= no code
SDM=no code
VTD= B2947 History
MSM= B1860 History
TTM= no code
RSS= no code
Jul 9, 2009 at 9:09 AM
