1998 Cadillac SLS Car will crank good but won't start
1998 CADILLAC SLS
90,000 MILES • V8 • 2WD • AUTOMATIC
HELPHELP
I have Cadillac SLS (1998) and I was driving and felt a jult, then 5 seconds later it just cut off and wouldn't re-start. I tried to start it again, but it didn't. I let it sit for over 5 hours, then a complete day, and it only turns over and doesn't start. If it is something electrical...what could it be? or could it be a fuse of some sort that I can change myself? Do you know of any tests that I can perform myself with auto tools such as a volt meter to find out what the problem may be?
Thank you for your time and consideration.
Aug 26, 2008 at 12:13 PM
You need to find out if its fuel or spark problem do below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Aug 26, 2008 at 12:32 PM
