It is possible, depending on your own mechanical ability. Chances are probable you have an ignition cylinder failing, or failed. Easiest way to check is with an ohmmeter, and with the left side lower i/p insulator removed. If you find the harness that is exiting the base of the steering column, where is a large orange conduit with two small white wires that come out of it at the connector. If you measure across these wires, with a key inserted, it should read a value, something other than OL or open circuit. It is usually open, or reads a value, which corresponds to the pellet value in the key. With open circuit, the cylinder is faulty. Proper repair would be to replace the cylinder. It can be bypassed at the connector if you bridge it with resistors of the same value as your key.
Dec 7, 2009 at 9:48 PM
