Blower motor
CADILLAC SEVILLE
DAMIAN1000
I HAVE A 2002 SLS 85000 MILES,JUST HAD THE TRANSMISSION REPLACED 3 DAYS AGO, AND UPON RETURN I FOUND THE HEAT ADN THE AIR WAS NOT BLOWING IN THE FRONT. IT WILL WORK IN THE BACK UNIT, WHEN I HIT THE AUTO BUTTON I CAN HEAR IT CYCLING THROUGH THE MOTIONS. I HAVE CHECKED THE FUSE BOX UNDER THE REAR SEAT. I DONT KNOW WHERE THE RELAYS ARE LOCATED AND THE BLOWER MOTER IS. CAN I REPLACE THE BLOWER MOTOR MYSELF AND IF YES WHERE IS IT LOCATED AND THE RELAYS?
THANK YOU D :D
Oct 24, 2007 at 10:20 AM
BUZZSAW
  • 1,198 POSTS
[quote:72b21e568c="damian1000"]I HAVE A 2002 SLS 85000 MILES,JUST HAD THE TRANSMISSION REPLACED 3 DAYS AGO, AND UPON RETURN I FOUND THE HEAT ADN THE AIR WAS NOT BLOWING IN THE FRONT. IT WILL WORK IN THE BACK UNIT, WHEN I HIT THE AUTO BUTTON I CAN HEAR IT CYCLING THROUGH THE MOTIONS. I HAVE CHECKED THE FUSE BOX UNDER THE REAR SEAT. I DONT KNOW WHERE THE RELAYS ARE LOCATED AND THE BLOWER MOTER IS. CAN I REPLACE THE BLOWER MOTOR MYSELF AND IF YES WHERE IS IT LOCATED AND THE RELAYS?
THANK YOU D :D[/quote:72b21e568c]
blower motor is under the pass foot well
Oct 29, 2007 at 11:27 AM
