MY HEATER WORKS JUST FINE BUT MY AC WILL NIT BLOW COLD AIR. WHAT COULD THE PROBLEM BE? WHEN I TURN THE AC ON IT WILL BLOW, JUST NOT COLD AIR.
Feb 2, 2009 at 10:37 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
The most common cause of this is low refrigerant due to a leak in the system, your mechanic can vacuum down the system and check for leaks, normally it is a loose pipe of faulty O ring seal, get this check and don't try and top up the system with refrigerant as it must be measured and installed in the correct manner to make sure its working correctly.
