2000 Cadillac Seville No cold air
2000 CADILLAC SEVILLE
104,000 MILES • V8 • 2WD • AUTOMATIC
ROYAZ
My 2000 SLS has stopped blowing cold air. The compressor seems to be working and I do not see anything loose or leaking. The blower works well, it just blows hot air. Will adding R134a to the system help or is there something more that needs to be done?
Apr 9, 2008 at 10:13 AM
BUZZSAW
  • 1,198 POSTS
[quote:b15fce3eb9="royaz"]Air Conditioning problem
2000 Cadillac Seville V8 Two Wheel Drive Automatic 104000 miles
My 2000 SLS has stopped blowing cold air. The compressor seems to be working and I do not see anything loose or leaking. The blower works well, it just blows hot air. Will adding R134a to the system help or is there something more that needs to be done?[/quote:b15fce3eb9]
scan your codes, if you have codes for the AC it wont come on, push off and down on the mode button at the same time, with the key in the on position, write them down and post them here!
it also needs to have the freon level ck'ed before adding freom, too much will damage the system
Apr 11, 2008 at 6:10 AM
