1998 Cadillac Seville engine cuts off
1998 CADILLAC SEVILLE
JSUMLER
Engine Performance problem
1998 Cadillac Seville V8 Front Wheel Drive 91000 miles
Engine will suddenly cut off while driving. Engine will crank up as if no problem. Will cut off again in 30min. or longer.
shop replaced fuel filter & pressure regulator,spark plug wires & spark plugs. No help
May 25, 2008 at 8:22 PM
BUZZSAW
  • 1,198 POSTS
[quote:416d70b827="jsumler"]Engine Performance problem
shop replaced fuel filter & pressure regulator,spark plug wires & spark plugs. No help[/quote:416d70b827]
its probally your cranksensors
scan your codes for me, off and warmer on the heater controls at the same time, with your key in the on position write them down and post them here for me, look in your message center for the codes
May 27, 2008 at 2:50 AM
JSUMLER
reply to tech.
heater has a auto button and knob for warner
Are these what I press at the same time with key on?
j [email protected]
I do not get anything when holding them in
May 28, 2008 at 4:04 PM
BUZZSAW
  • 1,198 POSTS
[quote:3f2372f6be="jsumler"]reply to tech.
j [email protected]
I do not get anything when holding them in[/quote:3f2372f6be]
sorry sevilles are different, is there anyway for you to put a pic of the heater controls on here
May 31, 2008 at 1:50 AM
