AX1500 Code Scout Scannerâ€
Is it ok to do a new reading of codes with alot of driving having been done after a previous reading of codes without first clearing the previous codes from the car?
Do previous codes need to be cleared from the car first, before every new car code reading
to get a new or updated reading?
After the 1st reading I took the batteries out of the AX1500 so it was not storing the 1st reading.
1998 Cadilac Seville sls
The engine light came on 2 months and 1 week ago just as the add engine oil light also came on. I added more than 1 quart of oil. After driving around for awhile both lights went off.
1 week later I checked the codes with the AX1500 Code Scanner. #3 misfire P0303 pending,
MAF adjustment needed P0101 current, and MAF too high P0103 current codes showed up on the AX1500 coide scanner. The engine light was still not lit.
2 weeks ago the engine light came back on. I did a new reading with the AX1500 without clearing the old codes from the car, and the 3 same codes are still there.
Is that new reading with the same codes just the stored codes from 2 months ago or is that considered the most up to date reading?
Why is the #3 misfire still pending and not current 2 months later after 3 days a week local driving?
If I cleared the codes from the car now and then did another reading would the same codes show up but the #3 misfire would now show as current?
The 8 readiness tests were all ok on the first reading 2 months ago, and they were all ok on the recent second reading, but the engine light is now on for about 2 weeks after not being lit for 7 weeks of 3 day a week local driving.
I am now about to fix the car and then get it inspected. I will have to clear the codes. The code sacanner manual says that clearing the codes would also reset the readiness tests.
How many miles, how many drive cycles, what kind of driving, etc., must be done for all of the 8 tests to be all passed again. How can I tell if the #3 misfire affected the the catalytic converter, would that put out a code?
I am going to check the #3 spark plug because of a P0303 and try to adjust the MAF reading with your
forums previous advice because of a P0101 and P0103 code reading.
Nov 14, 2008 at 4:05 PM
