1994 Cadillac Seville Brake Pedal Goes to the floor
1994 CADILLAC SEVILLE
200,000 MILES • V8 • FWD • AUTOMATIC
BILLCADDY
The brake pedal of our 94 Cadillac Seville STS goes to the floor with the engine running. I have replaced the master cylinder and have not noticed any leaks at the brake cylinders. If i pump the brakes, it will build up pressure, or if i am sitting still and i spin the tires (it is winter here now) and i and hit the brakes right after, it works fine. I am wondering if there may be a problem with the vacuum booster, or ABS componants? Other than bleeding the brake lines again, I can't think of anything else.
Dec 29, 2009 at 6:09 PM
FACTORYJACK
  • 4,159 POSTS
It sounds like you just have air in the system. The reason it seems to work after spinning, is probably because of the ABS.
Jan 1, 2010 at 12:36 PM
