1989 Cadillac Seville MY CAR WONT START
1989 CADILLAC SEVILLE
MOM2TOMMY
Electrical problem
1989 Cadillac Seville V8 Front Wheel Drive Automatic
MY CAR WONT START WE LOOKED AT THE IGNITION SWITCH TUMBLER AND IT APPEARS TO BE WORKING PROPERLY BUT THE DRIVERS INFORMATION CENTER SAYS IT WONT START DUE TO THE ANTITHEFT SYSTEM CAN I RESET THE SYSTEM HOW DO I GET MY CAR TO START?
Apr 21, 2009 at 9:09 PM
FACTORYJACK
  • 4,159 POSTS
You have broken wires at the ignition cylinder. These are in the column, and the only repair is replacement of the cylinder. If you choose a used column, be aware that there are 15 possibilities of key values, and the chances of getting the same value are slim. A dealer can use a tool called interrogator to read your key value. You can bypass the cylinder, down at the connector at base of column, either with a new cylinder plugged in or, knowing the resistance value of your key pellet, putting a resistor across the harness side terminals.
Apr 21, 2009 at 11:55 PM
