1982 Cadillac Seville power windows
1982 CADILLAC SEVILLE
182,000 MILES • 6 CYL • 2WD • AUTOMATIC
KJOHYN1976
  • 4 POSTS
is there a way to get a power window up to stay until i have the time to replace the motor
Mar 15, 2008 at 2:00 PM
BUZZSAW
  • 1,198 POSTS
[quote:ebb81cbb34="kjohyn1976"]Interior problem
1982 Cadillac Seville 6 cyl Two Wheel Drive Automatic 182000 miles
is there a way to get a power window up to stay until i have the time to replace the motor[/quote:ebb81cbb34]
you can remove the motor and wedge a peice of wood in it
Mar 16, 2008 at 2:44 AM
CPOWDER
  • 16 POSTS
If your motor is not working.then for now you can run some power wire from your battery then splice the wireing connected to your window motor find out which of the wires is acceptable to power by touching the copper in each wire when you find the rigth one then connect the wire from the battey to the wire on you window motor.I think you have to have a ground too. but If that doesnt work for that quick minute then you need a new window motor.
Mar 16, 2008 at 2:13 PM
CPOWDER
  • 16 POSTS
oor find a wire that has power to it already an splice that wire an run a little line from the working wire to the shortage wire.IF you have a shortage doing it htis way can tell you if its a short or you need a new window motor
Mar 16, 2008 at 2:21 PM
BUZZSAW
  • 1,198 POSTS
[quote:2ca37b5cf1="cpowder"]oor find a wire that has power to it already an splice that wire an run a little line from the working wire to the shortage wire.IF you have a shortage doing it htis way can tell you if its a short or you need a new window motor[/quote:2ca37b5cf1]
there are only 2 wires to the motor, if the motor is bad it doesnt matter if you hook power and ground to it it wont work
heres a test you can preform, turn your key on to run the window, with the door open and the dome lite on operate the switch. does the dome lite dim at all? if it does the motor is bad if it doesnt the switch is bad. if its the switch, hit the switch hard with your finger repeatitly. it may work
Mar 16, 2008 at 6:16 PM
