[quote:2ca37b5cf1="cpowder"]oor find a wire that has power to it already an splice that wire an run a little line from the working wire to the shortage wire.IF you have a shortage doing it htis way can tell you if its a short or you need a new window motor[/quote:2ca37b5cf1]
there are only 2 wires to the motor, if the motor is bad it doesnt matter if you hook power and ground to it it wont work
heres a test you can preform, turn your key on to run the window, with the door open and the dome lite on operate the switch. does the dome lite dim at all? if it does the motor is bad if it doesnt the switch is bad. if its the switch, hit the switch hard with your finger repeatitly. it may work
Mar 16, 2008 at 6:16 PM
