EFI system
1978 CADILLAC SEVILLE
77,300 MILES • V8 • 2WD • AUTOMATIC
COWBOYSFOEVER
Have problem w/EFI 5.7 engine.Sometimes when accelterating,engine sputters like fuel is almost shut off.It seems to start best when cold,however it will when hot,at times.I have replaced:ECM/ECU,throttle position switch,spark decoder,high idle valve,spark plugs,S.P. wires,everything in dist.,all sensors on intake,injectors,even has new rebuilt engine.When it runs right,it,s perfect.When it acts up,I think it,s starving for fuel.Also installed both new fuel pumps & blew out gas lines,new fuel filters,cleaned gas tank.Are these years known to have problems w/EFI system?? thanks in advance..Jesse
Jun 28, 2010 at 2:06 PM
Hello Jesse,
I have had that same problem with a 1979 Seville. I replaced the coolant temperature sensor and the problem went away. Please inspect/replace and get back to us. Thanks for using 2Carpros.com
Jul 12, 2010 at 2:04 PM
SIERRA240
Hello
I have the same problem. where can I buy such a temperature sensor? I live in Switzerland and I do not find us.
Thank you for your help
Jun 13, 2011 at 5:24 PM
Any GM dealer will have it. You will need to search for a GM or Cadillac dealer on the web and have them ship it to you.
Jun 14, 2011 at 4:02 PM
SIERRA240
Thank you for your reply. Do you know a dealer who sends abroad?
I have already tried but without success. You know the part number for this sensor? Is this one like in the picture? Many thanks for your help.
if this does not work, I have to scrap the Seville since I no longer bring the car through inspection.
Jun 15, 2011 at 4:30 AM
Yep that is the sensor, I dont know any dealer here that will send abroad. sorry
Jun 15, 2011 at 6:18 AM
HEFE HOMES
I have a 78 Seville and I’m having issues with finding an ess decoder ? Can anyone Help me out please help!
Mar 1, 2018 at 5:42 AM
I'm sorry what do you mean by ess decoder?
Mar 3, 2018 at 3:11 PM
