fuel pump problem
CADILLAC
BTN1981
I have a 97 cadillac sls and my fuel pump is not coming on so first I checked the fuses all okay then checked the relay its was good so thinking it may be the key so went to dealership my friend told me lock cylinders go out due to the getting cut so I checked that out and found a bare spot on lock cylinder wires so I replaced the whole cylinder and key still nothing so I thought it had to be the pump so I pulled the tank checkd wires had power and ground so pulled the pump out and tested it works just fine dont know what to think other than anti-thief module cause even dont work but when it wants to
Nov 8, 2007 at 6:08 PM
BLACKOP555
  • 10,386 POSTS
check the relay and also check for cut wires on the fuel pump wiring harness.
Nov 8, 2007 at 6:56 PM
BUZZSAW
  • 1,198 POSTS
[quote:db7c93810d="btn1981"]I have a 97 cadillac sls and my fuel pump not coming on I checked all fuses and talked a friend about it and told me about the lock cylinder having problems with the wire getting damaged so I checked it out and there was a wire cut so I replaced it and still no fuel pump checked wires also I have power no ground and before when it did this i could disconnect the battery and the pump would start working again[/quote:db7c93810d]
did you put a new lock cylinder in? with new keys?
explain how you fixed it?
Nov 15, 2007 at 2:54 AM
