1994 Other Cadillac Models
1994 CADILLAC
17,300 MILES • V8 • 2WD • AUTOMATIC
AIRBORNE3116
all new tune-up parts,dist,cap,plugs,wires etc. car won't run. sometime run all day no problem, next day or any time shut off like engine turned off with key,won't start right after shuts off, come back later it starts,drive a few blocks shut off again. It have irregular pattern to run.94 caddy fleetwood 5.7 rear wheel drive.
Dec 11, 2009 at 4:36 PM
FACTORYJACK
  • 4,159 POSTS
When it won't run, try and identify what is lost. With the randomness, I would not suspect a fuel pump, but control could be possible. Pull a plug wire, create a gap to a ground and check for spark. It sounds more like an ignition module type fault. When it won't start, shoot some starter fluid or carb cleaner down the throat and see if it tries to fire. If not, you lost spark.
Dec 11, 2009 at 9:56 PM
