1985 Cadillac Fleetwood Radiator Fan Relay
1985 CADILLAC FLEETWOOD
SINGS10R
Engine Cooling problem
1985 Cadillac Fleetwood V8 Front Wheel Drive Automatic
Radiator Fan Relay, where is it located and is there only 1 for both fans or 1 for each fan?
Apr 11, 2010 at 7:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
should just have one cooling fan relay on the right side of firewall in the engine compartment
Apr 11, 2010 at 9:26 PM
SINGS10R
I tested the fan motors by turning on the Ac after the engine ran a few minutes. Both fans came on. Would the relay still be a problem? Also, I see no relay on the firewall but I have 2 side-by-side closer to the front of the car on the driver's side.
Apr 12, 2010 at 8:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if fan comes on then relay is good. check engine coolant temp. sensor if fan does not come on at proper temperature.
Apr 12, 2010 at 10:16 AM
