2002 Cadillac Escalade Ext service engine soon
2002 CADILLAC ESCALADE EXT
170,000 MILES • V8 • 4WD • AUTOMATIC
HANDIMAN57
service engine soon warning stays on even though car seems to run fine. It happened shortly after a new inspection sticker test was successfully completed.
Also stability control warning light is on
Oct 13, 2009 at 7:52 PM
FACTORYJACK
  • 4,159 POSTS
You would need to have it scanned for fault codes, that would narrow down the possibilities of what is causing the light. A code reader will give you Engine/Trans fault codes, the stability fault may require a scan tool that is capable of accessing the system.
Oct 26, 2009 at 10:08 PM
