service ride control
2003 CADILLAC ESCALADE ESV
104,345 MILES • V8 • AWD • AUTOMATIC
RONALD BALL
yes the suv saying service ride control. well i have replaced r/ rear air ride shock. it was leaking air, a very little. but need to reset. and hope this is all is wrong. the air compressor in the left rear don't seem to be coming on .where is the fuse or relay for this compressor located ?
Apr 9, 2010 at 2:39 AM
HMAC300
  • 48,601 POSTS
9 times out of 10 it is the because the rear shocks are leaking here is instructions and diagrams so you can fix the problem you can get the parts on Amazon for $245.00 AC Delco
https://www.amazon.com/gp/product/B001KSC6LM/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B001KSC6LM&linkId=49127f7bdf3bbf8cb6192cdb13846773
Jul 5, 2010 at 12:19 PM
BOOPERIII
The dealer wanted $1200.00 to fix it.
Feb 12, 2019 at 12:32 PM
MARTIJ
i have a 108,000 mi on my cad esv the service ride control is on my display message on dash but truck rides fine .how do i fix this or reset the message?
Feb 13, 2019 at 10:48 AM (Merged)
FACTORYJACK
  • 4,159 POSTS
When you start the vehicle, or apply some load to the rear, do you hear the compressor activate to level the vehicle. Most cases involve an inoperative level ride due to either a faulty compressor, or circuit faults that create an inoperative compressor. If the compressor is faulty, look for a condition that may have contributed to it, like split shock bladders or lines. If an exhaust solenoid fault is detected, it is integral to the compressor. Aside from hearing the compressor operate, you can also investigate and check the shocks for some pressure in the bladders, it should have some.
JDJASSYD
My 2004 Cadillac Escalade ESV shows up a warning "SERVICE RIDE CONTROL" each time I start the engine. I got it examined from my mechanic and he replaced the driver side front wheel bearing as the old one had worn out. This did not correct this warning lite. He scanned the truck and got with an error code of CO660.
Please tell me how to fix this issue.
Is this something very serious or is it something to do with the electronics on the truck.
Please advice. Thanks a lot to all for your help with this.
FACTORYJACK
  • 4,159 POSTS
C0660 is an exhaust solenoid fault relevant to the automatic level control. It can be wiring, or a failed solenoid, which is part of the ALC compressor. To diagnose it, you would more than likely need a scan tool, a wiring schematic, and a meter.
JDJASSYD
Thanks for the prompt reply Gstacey. So what kind of scan tool would I need to diagnose it further? Or can I have my mechanic check the ALC or the Solenoid and if anything is faulty replace the same?
Please advice.
FACTORYJACK
  • 4,159 POSTS
You need a scan tool that will access the ALC system. I don't know if aftermarket scanners will accomplish that task. If your mechanics scanner has that capability, he should be more than capable. By accessing, I mean more than just reading codes. It would need to perform special functions like outputs, and have the ability to read data. Simply stated, if you can energize the relay circuit, and verify it at the compressor, then it needs a compressor.
