Diagnosis code C0286?
CADILLAC ESCALADE
LUPCHURCH
Cadillac Escalade AWD 2002, 91K, 6.0L
Yesterday my message center said "Service stability system." I left the car at my local repair garage and received the ECM diagnosis code C0286. When I looked up the code it says "C0286 - ABS Indicator Lamp Circuit Shorted to B+".
Can you tell me what needs to be replaced if anything. My repair garage says it needs $1,100.00 to repair. I need a second opinion.
Thanks for your help.
Feb 9, 2007 at 3:28 PM
CHEVY22
  • 1,375 POSTS
actually the code is mpa switch remins open or closed , the ebcm (electronic brake control module) may have to be replacedas it is internal and the price is in the right range , good luck your shop sounds good
Feb 21, 2007 at 7:30 PM
CD24747
[quote:0cdc4bcb89="lupchurch"]Cadillac Escalade AWD 2002, 91K, 6.0L
Thanks for your help.[/quote:0cdc4bcb89]
I had the same problem and it was a steering wheel sensor. It was $55.00 on ebay and it took me about 10 minutes to put it in. I dont know what my error code was but it was an easy cheap fix. just look under the dash and it is a round white piece around the steering rod. One screw and the rod comes apart and it slides out. Just unplug and slide it off, slide the new one on and plug it in. hope I helped.
Aug 31, 2007 at 11:25 PM
