p0171 p0174
2003 CADILLAC ESCALADE
141,000 MILES • V8 • AWD • AUTOMATIC
JAY-P81
I own 2003 Cadillac escalade the check light came on and I brought it to the mechanic.The codes he pulled up were p0171-p0174 fuel trim lean bank 1 and 2,they were the oxygen sensors,so I had them replaced.I also replaced the fuel pump and gave it a tune up, and also ran a vaccum test on it and have checked my engine for more problems but none apparently.But my check light is still on and my cady is running weird please help I'm at the end of my rope
Dec 16, 2008 at 12:00 PM
BRIAN 1
  • 1,030 POSTS
I have found the MAF sensor can cause these problems and the MAF is a normal maintenance item if you have not installed a new one recently I would give that a try.
Here is a guide.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Here is some book wisdom.
A cold rough idle that diminishes as the engine warms up.
Possible DTCS P0171, P0174, or P0300.
Random misfires at idle.
Recommendation/Instructions:
The intake gasket seals may be leaking around the intake ports, causing a lean condition. The intake gasket seals may leak around the bottom side of the port, making it a challenge to detect the vacuum leak. The technician may also notice lower than normal MAF readings if the intake seals are leaking.
If leaking intake gasket seals are found, replace the intake gaskets. During the repair be sure to use the current GMSPO part number for replacement intake gaskets. The current GMSPO part number for intake gaskets will have a teal green intake gasket seal. The old version of the intake gaskets were orange in color. Use only the teal green colored gaskets for a repair.
Check for vacuum leaks again you might find a problem.
please post back with what you find.
Dec 16, 2008 at 1:16 PM
JAY-P81
Yep I replaced the MAF which was totally dirty and it has never run so good. thanks for the help I love this site.
Dec 19, 2008 at 1:06 PM
