I'm hearing a noise in my vehicle and it only makes it when I am accelerating or braking there is a small leak in the axle seal where the half shaft bolts up. Even though I have checked and filled the gear lube it still makes this noise.
I have checked the brakes and backing plates on my escalade to see if that is the sound I am hearing. Nothing is rubbing or squealing there.
the sound only occurs when I'm turning or under load of acceleration I need to know if I should change all the bearings in the diff., do they all have to be checked or can the axle bearings be changed.
I am almost positive this is the problem I would like a second opinion.
Thank you for your time
Eric
Eric
May 20, 2009 at 10:38 AM
