2002 Cadillac Escalade
2002 CADILLAC ESCALADE
LALVAREZ
Transmission problem
2002 Cadillac Escalade V8 Two Wheel Drive Automatic
When i shift the gear it shift but would not engaged and produced a loud sound?
Aug 3, 2010 at 6:32 AM
FACTORYJACK
  • 4,159 POSTS
If it has no forward or reverse gears, and the cable is making shifts, it could possibly be a fault in the transfer case, or even the transmission. If you can isolate where the noise is coming from, or perhaps drain the fluid, you might find some evidence. I would drain the transfer case first, and if you find no sign, remove the trans pan.
Aug 5, 2010 at 10:05 PM
