What I would do first is set them all at zero lash when valves are closed, and check a cylinder to see if it has compression. The procedure calls for one full turn after zero, but we want to know if zero lash gives you some squeeze. If you still don't have compression at zero lash, were the heads serviced? At that point you would want to consider a cylinder leakdown test to find out where your air leak is. I included the GM procedure, but it would not be the first time that service info was incorrect.
Here is the gm procedure:
Valve Clearance Adjustment
Turn the valve rocker arm nuts clockwise until all of the valve lash is removed.
Turn the crankshaft clockwise until the alignment mark on the crankshaft balancer is aligned with the notch in the engine front cover tab.
Look at the number 1 cylinder valves as the crankshaft balancer alignment mark approaches the notch in the engine front cover tab. If a valve moves as the alignment mark moves into position, the engine is in the number 6 firing position. If this happens, turn the crankshaft clockwise 1 revolution in order to reach the number 1 cylinder firing position.
With the engine in the number 1 firing position, adjust the exhaust valves for cylinders number 1, 3, 4, and 8 and the intake valves for cylinders number 1, 2, 5, and 7.
4.1. Turn the valve rocker arm nut counter clockwise until the valve lash is felt in the valve pushrod.
4.2. Turn the valve rocker arm nut clockwise until all the valve lash is removed.
Zero valve lash can be felt by moving the valve pushrod up and down between your thumb and forefinger until there is no more up and down movement of the valve push rod.
4.3. When all the valve lash is removed, then turn the valve rocker arm nut clockwise 1 additional turn (360 degrees).
Turn the crankshaft clockwise 1 revolution until the alignment mark on the crankshaft balancer is aligned with the notch in the engine front cover tab.
With the engine in the number 6 firing position, adjust the exhaust valves for cylinders number 2, 5, 6, and 7 and the intake valves for cylinders number 3, 4, 6, and 8.
6.1. Turn the valve rocker arm nut counter clockwise until the valve lash is felt in the valve pushrod.
6.2. Turn the valve rocker arm nut clockwise until all the valve lash is removed.
6.3. When all the valve lash is removed, then turn the valve rocker arm nut clockwise 1 additional turn (360 degrees).
Oct 26, 2009 at 10:36 PM
