2000 Cadillac Escalade Dash board lights out
2000 CADILLAC ESCALADE
115,000 MILES • V8 • 4WD • AUTOMATIC
THECARMAN
Hi I have a 2000 Cadillac Escalade while I was driving at night and all my dash lights and temp control lights as well went out came back on and then went out again. Also my tail lights are off but my brake lights work. Thank you in advance
May 11, 2008 at 2:12 PM
MASTERTECHTIM
  • 4,750 POSTS
i woulsd suspect the headlight switch in this case. if you remove the switch and check for power at the brown or gray wire and there is none with the lights on then either the fuse is blown or the switch is bad.
May 11, 2008 at 4:07 PM
