2000 Cadillac Escalade
2000 CADILLAC ESCALADE
164,000 MILES • V8 • 4WD • AUTOMATIC
RHIGHSMITH06
I need to change the Camshaft Position Sensor but I cant find it where is it? Also is the ECM and PCM the same part or are they different?
Jul 5, 2009 at 4:27 PM
HMAC300
  • 48,601 POSTS
The cam sensor should be at the front top of the engine. It might be hard to see it will have a either a 8mm head bolt or 10mm head bolt holding it in. ECM means Engine Control Module and PCM means Powertrain Control Module. Yes they are the same.
Oct 27, 2009 at 4:03 PM
