1999 Cadillac Escalade MISFIRE
1999 CADILLAC ESCALADE
119,687 MILES • V8 • 4WD • AUTOMATIC
LADELL63
  • 4 POSTS
119687 MILES , WHY DOES MY VEHICLE READS MISFIRE
Sep 21, 2009 at 10:59 PM
FACTORYJACK
  • 4,159 POSTS
Often times there is deposits in the poppet nozzles. This can sometimes be corrected by cleaning the injectors. The trick is finding a chemical that will break down the deposits. The stuff that is added to the tank is usually sub-par. Most often it takes something like a top engine cleaner, diluted with gasoline, and fed with a pressurized can. This is one possibility, usually occurs more cold, and diminishes as it warms, but not always. If it is missing under load, it may be ignition related, plug/wire etc...
Sep 21, 2009 at 11:21 PM
