A/C compressor will not come on
1998 CADILLAC ELDORADO
101,000 MILES • V8 • FWD • AUTOMATIC
RCSSR
  • 6 POSTS
System stopped working, compressor will not come on. Dashboard signals "check A/C system" and "low refrigerant pressure, A/C off" alternately. Mechanic evacuated and recharged the system with no change. He then jumped out the A/C relay in the fuse box under the hood and the compressor came on. System then worked flawlessly and was 45 degrees at the interior vents. Everything works fine with the jumper wire. Prior to recharge the inline filter (plastic) was replaced (there was no debris on it). New A/C relay did not correct the problem. I bought a climate control assembly for the dashboard and replaced the blower motor on the firewall, I even bought a new computer and nothing will make the compressor come on, but obviously the system is able to work fine. Tried to jump out the two sensors on the high side pipe that runs across the firewall L to R. Nothing will make the compressor come on (other than jumping out the relay) or the alerts go away on the dash. Disconnected the battery at every repair attempt. The heater, the defroster (without the compressor coming on) and the blower all work fine. When you press the A/C button on the climate control, the system comes on but blows warm air. One of the mechanics I spoke to said the 'fan controller module' is bad but I don't know where that is or if it could be the culprit. My mechanic (and I) have given up. Help
Sep 23, 2008 at 1:42 PM
2CARPRO JACK
  • 11,533 POSTS
Is it still saying "A/C low" or any other a/c warning on the driver info center? Cadillac's wont let the compressor come on til the codes have been cleared through the on-board system.To enter self diagnostics
Key on, press "warmer" and "off" at the same time,hold down until info center changes to diagnostic. Then press fan low until "ACM" is displayed.Then fan high until "ACM codes" is displayed.Then fan low until "clear ACM codes" is displayed. Then fan high to clear the codes "ACM codes cleared " will display. Turn key off.
Sep 24, 2008 at 8:05 AM
RCSSR
  • 6 POSTS
I followed your instructions to clear the ACM codes but the compressor will still not come on. I am still getting the messages "low refrigerant A/C off" and "Service A/C system". What now?
Sep 24, 2008 at 12:38 PM
2CARPRO JACK
  • 11,533 POSTS
Then the problem isn't fixed.. sounds like the pressure sensor (located in the high side line) is bad if the system is full. If there are any error codes, the car wont let the compressor turn on.
Sep 24, 2008 at 1:13 PM
RCSSR
  • 6 POSTS
There are two sensors on the high side (small tubing) and one big one on the low side (one inch + diameter tubing). Which one of the two would it be? one is near the dryer and one is on the drivers side. Can I replace it without loosing the Freon and/or can I jump it out to see if it is bad (I think I may have done that already??) If I understand you correctly, even after I find a problem and fix it I will have to reset all the error codes on the dash. Can I reset them all or just the ACM? I know this is a pain but I have been at this for weeks and as you can see at considerable expense.
Sep 24, 2008 at 4:35 PM
2CARPRO JACK
  • 11,533 POSTS
My software doesn't say which is which... what color are the wires to the two switch's? I will try looking them up in the wiring diagram.
Sep 25, 2008 at 7:43 AM
RCSSR
  • 6 POSTS
The low side (large tube) sensor has a pink and a green wire. The high side sensors are black and grey on the passengers side of the tube and dark blue and black on the drivers side. Let me know which one and if I can jump it out before I replace it. Also can I replace it without loosing the Freon?
Thanks,
Sep 25, 2008 at 12:52 PM
2CARPRO JACK
  • 11,533 POSTS
Im showing a dark blue/dark green for the high side pressure switch.I wouldnt jump it. According to Mitchell you dont have to discharge the system, but honestly I would just to be safe
Sep 26, 2008 at 7:54 AM
RCSSR
  • 6 POSTS
I bought the new high pressure sensor from Cadillac but we still have problem. There are two sensors on the high pressure line that runs along the firewall from right to left. Parts dept at Cadillac says there is only one according to their diagram. I don't want to replace the wrong one (assuming that this is indeed the problem) and loose the Freon multiple times. The high pressure line starts at the passengers (right) side of the firewall and travels across to the drivers (left) side of the car and then turns down below the master cylinder and then turns forward toward the condensor and attaches to it. That line looks like 1/2 inch diameter (guess) aluminum tubing. The line coming out of the evaporator (enclosed in the fan box assy) is 3/4 inch diameter (guessing) and gets reduced to 1/2 inch at the coupling that joins it to the high pressure line. There is a sensor on that 3/4 inch line (right before the coupling) that has a black and a grey wire attached to it and when I jump out the relay to engage the compressor that line gets ice cold. It changes to extremely hot right at the coupling point where it is ruduced to the 1/2 iinch line. That 1/2 line gets untouchably hot all the way across the firewall. The second sensor with the blue and black (looks black to me and not green) is located on that 1/2 in line all the way over on the drivers side of the firewall. Which one do I replace? Is the proceedure after replacement to clear the codes on the diagnostic (all of them or just the ACM?) and then recharge the system, or the other way around. Thanks for your patience
Bob Smith
Oct 2, 2008 at 10:09 AM
2CARPRO JACK
  • 11,533 POSTS
Try using a voltmeter on the switch plugs when comp is running, one is s switch and the other is a senor so the switch will simply turn on and off with 12 volts while the other will send a signal that is of varying voltage.
Oct 2, 2008 at 10:32 AM
RCSSR
  • 6 POSTS
I still have the problem. I have replaced the two temperature sensors and the two low pressure sensors. I have cleared the ACM codes through the onboard diagnostics that you showed me. The system is full and works fine when you jump out the relay in the fuse box under the hood. Both low pressure sensors read 12 volts (+ - ) and both temp. sensors read varying 4-5 volts. I have even tried jumping out all four of them but the compressor will not engage. The ONLY way it comes on is when I jump out that relay (replaced it three times to be sure it was not the culprit). Do you have any more suggestions? Lastly if I take it to Cadillac will their diagnostics be able to read the problem and would a heat/AC shop have the same equipment or is Cadillac my only option? I am at my twits end now.
Thanks for you time,
Bob Smith
Nov 8, 2008 at 11:40 AM
CUTECHICK57
Wow! Thanks for the information on the A/C compressor. It worked and saved us lots of dough!
Apr 13, 2014 at 1:02 PM
CADDYMAN64
1997 El Dorado compressor not coming on due to low refrigerant.
So. I cleared all codes then started the car and turned on the A/C. The compressor immediately came on. While it was on I added more refrigerant to it. It took the refrigerant and started blowing very cold air.
So, clearing the codes tricks the computer into thinking the car is not low on refrigerant and the compressor immediately came on as soon as I touch the A/C button.
I hope this will help someone having the same problem.
Jul 29, 2019 at 10:05 PM
Hi Caddyman,
This post is over 5 years old so I doubt they will respond however, thanks for the info. As for what happened when you cleared the codes, depending on what code you had it didn't "trick" the compressor. You just cleared out the information from the module that was preventing the compressor from coming on. This basically made the module forget what the issue was and enter back into its monitoring mode. Again, depending on the codes it was probably a two trip failure code so it doesn't reset immediately which allowed the compressor to come on and you could fill the system. Hopefully that was your only issue and they don't come back. If they do just start a new post with your specific issue. Thanks
Jul 30, 2019 at 3:43 AM
TOM LYON
Followed the reset procedure closely. I couldn't get my A/C running even though I had it filled, jumpered the hi and low psi sensors, etc. I am an HVAC tech and was out of ideas. I kept reading about resetting the PCM and/or ACM plus kept reading that Cadillac fault codes latch and will not allow whatever it monitors to just start working again. ACM fault codes must be reset. Figuring out how to do that s the trick. JACK42 had the right sequence. It worked after messing around for days. I already had the problem fixed and only needed to reset the ACM. Until it is fixed, you won't be able to reset it and stay that way for long. Thanks Jack42!
Aug 3, 2020 at 10:32 AM
Thanks for the update. Glad it worked out for you. Please come back in the future if you need help on different issues. Thanks
Aug 3, 2020 at 7:52 PM
