1996 Cadillac El Dorado alternator replacement
1996 CADILLAC ELDORADO
JIM SHERIDAN
Electrical problem
1996 Cadillac El Dorado V8 Four Wheel Drive 140,00 miles
How do you replace alternator on a 1996 eldorado ?
Nov 6, 2008 at 2:53 PM
Hi:
This isn't that hard of a job. All you need to do is first disconnect the battery. After that, remove the belt. Now, unbolt unclip any wiring to the rear of the alt remembering where they were so you can replace them on the new alt. Next, remove the bolts holding the alt on the car and remove the alt. Replace it in the reverse order.
I hope this helps.
Nov 18, 2008 at 10:39 AM
