1995 Cadillac El Dorado Cooling Fan
1995 CADILLAC ELDORADO
63,000 MILES • V8 • FWD • AUTOMATIC
EKOONCE
At what radiator temperature should the cooling fan turn on during idling?
Nov 28, 2009 at 4:02 PM
To check the temperature at which the fan comes on, turn the A/C off and keep the engine running until it reaches normal operating temperature. Most fans should come on when the coolant reaches about 200 to 230 degrees. If the fan does not come on, something in the control circuit is defective. Resistance checks should then be made on the temperature sensor or switch, and a voltage check on both sides of the relay (you will probably need a wiring diagram of the fan cooling circuit on your vehicle to identify the relay terminals and wiring connections).
Nov 29, 2009 at 5:22 AM
