How do you remove the engine from this caddy, what do I have to do to get it out from the bottom.
May 30, 2010 at 5:24 PM
FACTORYJACK
CERTIFIED EXPERT
To get it out from the bottom, you would take the entire powertrain, and seperate the engine from the trans at that point. You can remove it from the top on this vehicle. It is most recommended to remove the intake, starter, and maybe even the water pump housing(crossover). This will create much needed access, and clearance when lifting out of the vehicle.
