1992 Cadillac El Dorado A?C compressor off - low refrigeran
1992 CADILLAC ELDORADO
ALGUILLAUME
Air Conditioning problem
1992 Cadillac El Dorado V8 Front Wheel Drive Automatic
What is the procedure to get my compressor turned on so I can load refrigerant into system?
Nov 3, 2009 at 2:31 PM
DOCFIXIT
  • 18,828 POSTS
On accumulator pull plug off low pressure switch jumper terminals this will turn on comp if rest of system operational. Was system opened? has it been vacuumed down?
Nov 3, 2009 at 3:02 PM
ALGUILLAUME
The system has not been opened. It has been converted to R-12 at some time before I got it. It has not been vacuumed out.It did lose some pressure when I originally tried to load it and realized that it was not taking it in. It shut off do to low refrigerant as all cadilac's do.
Is the accumulator the large pill shaped piece that has the low pressure lines coming off it?
Is the switch located on the line or on the accumulator?
Thanks for your help!
Al Guillaume
Nov 4, 2009 at 9:08 AM
DOCFIXIT
  • 18,828 POSTS
Large can thing switch on it or in low press line coming from it.
Nov 4, 2009 at 2:37 PM
