1992 Cadillac El Dorado
1992 CADILLAC ELDORADO
JENNIFERJAYLA
1992 Cadillac El Dorado 4 cyl Automatic
Where is the starter located and how do you replace it?
Sep 30, 2009 at 3:29 PM
FACTORYJACK
  • 4,159 POSTS
Assuming it is a 4.9l, it is on front lower portion of engine at transmission joint. Remove the flywheel shield, two bolts hold the starter to block, remove the wires(battery disconnected), and the starter. It may need the exhaust loosened, or Y-pipe removed to remove the starter completely. In some cases, there is also a bracket at the end of the starter for support, it would need removed also.
Oct 1, 2009 at 9:11 PM
