1989 Cadillac El Dorado brake line repair
1989 CADILLAC ELDORADO
55,000 MILES • V8 • FWD • AUTOMATIC
BRIANBRODY
brake line that runs to the rear ruptured due to rust. the bad part of the line was cut out and a new piece added using compression fittings. QUESTION= is it legal and/or safe to fix brake line as described above? (several note on the web say to never use compression fittings due to high pressure in the lines)
thanks
Oct 27, 2008 at 8:55 PM
DOCFIXIT
  • 18,828 POSTS
Line should be replaced with one piece. Compression fittings will fail.
Nov 4, 2008 at 9:41 AM
