1989 Cadillac El Dorado 89 eldorado rough running
1989 CADILLAC ELDORADO
300,000 MILES • V8 • FWD • AUTOMATIC
HENGSTER
  • 5 POSTS
Hi i have an 89 eldorado with 4.5 v8, recently ive removed the engine to reseal all gaskets except head gaskets and replaced timing chain and gears. when i put it all back in, its hard to start, running rough, and wont rev up. theirs a E036 code for idle speed control (short circuit) and E021 for tps which i've changed but dont have info on how to adjust it correctly, and SES light comes on intermittent. it almost seems like timing is off but i double checked everything related to timing referencing to my Haynes repair manual.
Jul 19, 2009 at 11:25 PM
RACEFAN966
  • 5,029 POSTS
Ok first off how did you time it? DId you take a paper clip and jump term A and B at the Diagnostic connector near the parking brake pedal just below the dash? You should have saw a message that said "set timing" in the driver information center.
Now as for the TPS setting you can either enter the diagnostic mode throught the climate control panel with key on engine off tps reading shoud read .5 - .5 if not then loosen the screws that hold the tps and adjust it till it does. If this can't be done then you will need a digital multi meter and a paper clip, back probe the dk blue wire at the tps with the paper clip and then hook up the multi meter and set is on the 20 volt scale. With key on engine off throttle closed it should read .45 to .5 volts and at wide open throttle should read 4.5 to 5 volts. Let me know how it goes.
Jul 20, 2009 at 10:27 PM
PEAR69
  • 1,482 POSTS
A E036 trouble code is an EGR pintal position out of range code. This usually means that the EGR valve and system must be cleaned or the egr valve has failed.
The E021 is a short in the signal wire of the TPS. Look for pinched wires or shorts in the signal wire.
Either one or both of these codes will cause the engine to run rough.
Jul 20, 2009 at 10:32 PM
HENGSTER
  • 5 POSTS
i figured out the problem, it was bad distributor. i have 2 new problems, cooling fan does not kick in by it self but works if i turn on a/c and the brake light does not go off, ive checked brake fluid and e-brake released.
Jul 24, 2009 at 6:46 PM
RACEFAN966
  • 5,029 POSTS
Ok if you would check the ohms on your coolant temp sensor. Do this cold and simply unplug and ohm across term on the sensor not wire harness and then get back to me with the ohms and the air temp at the time of the test.
Jul 25, 2009 at 9:27 AM
HENGSTER
  • 5 POSTS
i replaced the coolant temp sensor and did not fix the problem. checked fuses and relay, is there another sensor for the cooling fans?
Jul 27, 2009 at 10:05 PM
RACEFAN966
  • 5,029 POSTS
The cooling fan control module needs to be tested to see if it working as it should. So check the orange wire going in for power and we will take it from there. The fan module is on the bottom of the upper radiator support on the right (passenger) side.
Jul 28, 2009 at 9:29 AM
HENGSTER
  • 5 POSTS
i beleive i found the cooling fan module, and there is battery voltage at the connector with orange and black wires.
https://www.2carpros.com/forum/automotive_pictures/384886_black_240_001_1.jpg
Jul 28, 2009 at 10:31 PM
RACEFAN966
  • 5,029 POSTS
Ok so tell me how many fans do you have 1 or 2? Do they work if you turn on the A/C? Yes that looks like the cooling fan module. Get back to me so I can walk you through the proper test thanks.
Jul 29, 2009 at 9:30 AM
HENGSTER
  • 5 POSTS
there is 2 fans, one on the back of rad and one in front. fans work when i turn on a/c.
Jul 29, 2009 at 6:23 PM
RACEFAN966
  • 5,029 POSTS
Ok check the ohms of resistance between the black wire (next to the orange wire) and ground let me know what you find. Then after you check that I need you to back probe the green wire and then run the car and get up to temp (don't let it over heat) and with you volt meter hooked up do you get power there when up to temp where the fans should come on? Then check the brown wire. If so then the control module is bad. If you get no power then we need to check the engine control module and the body control module to see which isn't sending the power. Let me know what you find.
Jul 30, 2009 at 9:59 AM
