1982 Cadillac El Dorado
1982 CADILLAC ELDORADO
76,870 MILES • V8 • FWD • AUTOMATIC
TWIZTID737
i replaced the distribitur cap the coil the rotor button and the plugs and wires but it is still missin i cant figure it out do i need to adjust the timing
Jun 12, 2009 at 4:23 PM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jun 12, 2009 at 4:26 PM
