2006 Cadillac DTS Cold Start Clattering
2006 CADILLAC DEVILLE DTS
65,000 MILES • V8 • FWD • AUTOMATIC
PLOWBOY53
Whold startat would cause my DTS Northstar engine to clatter on a cold start?
Dec 14, 2009 at 9:23 AM
Does it sound more like a rap or a ticking? Also, does the oil light go out right away or does it stay on for any length of time? Finally, is the oil full, and how long does it take for the noise to stop?
Dec 14, 2009 at 9:15 PM
PLOWBOY53
Wh en I started it on a sub-zero morning recently, it made a loud ticking noise which went away after about a minute or two. There is plenty of oil in it and on previous starts, it did tick a little bit, but on the very cold day, it was loud enough to make me think what the heck was going on. The light goes out right away after I start it, and a Caddy service manager said that it's normal for a Northstar engine to do this. I just think that Cadillac should get these engines dialed in so they don't sound like some clunker when theyr'e left out overnite in cold weather. This morning I started it in the garage and it made a light ticking noise which went to a quiet idle after a very short time. Thanks, Frank
Dec 15, 2009 at 3:27 PM
That is a lifter ticking while it pumps up. Have you ever tried using synthetic oil? It is more expensive, but doesn't react to temp changes like conventional oil will. Conventionial oil will get heavier when it gets really cold synthetic won't. You may want to try it once to see if that helps.
Let me know if it helps, and thanks for using 2carpros.com.
Dec 16, 2009 at 8:57 PM
PLOWBOY53
Next oil change I'm going to put in Amzoil and see if that helps. Thank you, Frank
Dec 19, 2009 at 12:34 PM
Frank:
Try that and make sure to get an oil filter with an anti flowback valve. Let me know if it helps.
Have a great holiday, and thanks for using 2carpros.com.
Dec 19, 2009 at 5:14 PM
