2004 Cadillac DTS code
2004 CADILLAC DEVILLE DTS
70,000 MILES • V8 • FWD • AUTOMATIC
BACKLASH
I have a lean code. What could be wrong and how do I fix it?
Thank U
Feb 17, 2009 at 10:10 PM
FACTORYJACK
  • 4,159 POSTS
You have a lean code for just one bank, or both? A lean code on just one bank could be O2 sensor, dirty injector, intake leak, or other vacuum leak that would only affect one side. If you have a lean code for both banks, you could have a skewed or dirty mass airflow sensor, leaking plenum, high alcohol contented fuel, an open vacuum source on the intake. Most typically, if it is both banks, the plenum boot between the intake and throttle has a split in it. This is usually on the bottom side, and can be somewhat intermittent. It can often be accompanied by a higher than normal idle speed.
Feb 18, 2009 at 9:41 PM
BACKLASH
You are correct on the ripped boot. We changed it today and decided to change the manifold gaskets also. All better now. Thank you for your time....Peter
Feb 18, 2009 at 11:44 PM
