2004 Cadillac DTS a/c stops blowing
2004 CADILLAC DEVILLE DTS
BROKE 1
Air Conditioning problem
2004 Cadillac DTS V8 Front Wheel Drive Automatic
what could cause my a/c to stop cooling sometimes, it will start off working fine & then it will stop cooling ,it fills like its blowing fresh air though the vents,sometimes you can turn it off &wait a little while & it will come on & maybe it won't ?
May 30, 2010 at 2:26 PM
FACTORYJACK
  • 4,159 POSTS
Without looking at system pressures when this happens, there could be a few possibilities. The compressor could be shutting down for various reasons. If the system is still pumping, it could be restriction causing icing, or a malfunctioning expansion device. The fact the shutting it down for a period brings back cooling, I would suspect the latter. You would need to have the system checked out.
May 30, 2010 at 3:03 PM
